Can i get spatial mapping mesh normals in a shader?
I plan to visualise the spatial mapping mesh using a shader that will make use of normals. As a first step i made a shader that just visualises the normals. The shader works fine in Unity in the editor, even on meshes i downloaded form the device. I know i can get the normal if i raycast against the mesh. The problem however is that the exact same shader that works in the editor does not work on the device. The normals for all vertices seem to point to positive z. I'm using appdata_base.normal to get the normals. I also tried defining a struct that has a float4 with NORMAL semantics. Is there another way to obtains mesh normals that will work on the device?
Tubeliar ✭
@DanAndersen you were right after all, the normals are simply not computed.
I put some objects in the scene with normals so that i could verify my shader does work on the device. I wrote a script that periodically retrieves all spatial mapping meshes and checks if they have normals, which they did not. I then used mesh.RecalculateNormals() on all the meshes and then they have normals until the SpatialMappingObserver updates them.
So it seems the physics engine computes its own normals or perhaps it computes only the normals it needs. The normals that were on the mesh i downloaded from the device were in fact on the mesh; The import setting was set to import the normals, not calculate them. So these normals are perhaps calculated on export or at some other time, but they are not representative for the spatial mapping meshes the device uses.
I believe that for the purposes of optimization, the normals are not precomputed.
See:
https://docs.unity3d.com/ScriptReference/Mesh.RecalculateNormals.html
https://developer.microsoft.com/en-us/windows/holographic/spatial_mapping#visualization
https://developer.microsoft.com/en-us/windows/holographic/Spatial_mapping.html#mesh_processing
You can also calculate the normals by adding a geometry shader and doing it there.
This sounds logical but i don't think this is true. Like i said, when i raycast against the meshes they do have normals, but maybe this is for physics only. Also, when i download a mesh from the device it does have normals, although Unity might compute them on import.
I guess i'll have to test on the device whether or not the mesh actually has normals. Also i can test the shader on objects for which i know they have normals.
Unless I'm not overstanding this question, I guess the answer to this depends on the tools you're using. In DirectX/C++ & SharpDX/C# yes you can. I'm not sure how you do it in Unity however. I'm sure there has to be a way though.
Here's the example in C++/Directx
Dwight Goins
http://dgoins.wordpress.com
I noticed that my lights in the shader weren't effectiving anything below them. I eventually realised the normals on the mesh weren't correct. As such i added RecalculateNormals() in the OnDataReady method which is called as a result of the following call.
surfaceObserver.RequestMeshAsync(sd, OnDataReady);
public void OnDataReady(SurfaceData cookedData, bool outputWritten, float elapsedCookTimeSeconds) { cookedData.outputMesh.mesh.RecalculateNormals(); }
