Why does video recording crash, When I start Vuforia-Hololens sample app?
Hi, Guys.
I downloaded Vuforia-Hololens sample app and It work well without recording video.
But, If i start recording with video, then start sample app, the video recording is crash.
After removing ARCamera, I can record video.
I think this problem caused by ARCamera.
How can i solve this problem?
As I understand you can only have one application using the Camera function removing AR Camera means you have only one source the video. There are other threads which talk about this. Even if the ARCamera template is not used, it becomes active because the Victoria licence needs this to run. Of course these Vuforia HoloLens samples are early release and some sort of shared use is needed instead of exclusively by one app and for beta testing not for commercial use
Useful information. Thank you.
