Emulator fails running solution
When I am learning tutorial 211, I just follow the steps and want to run solution in an emulator instead of the device. The solution is built and deployed successfully, and the emulator is launched successfully.
But it only shows system page like this:
The project does not run automatically on it. Any idea?
OptionsDavidKlineMS mod
@RosieLiu,
Can you try disabling the Fitbox object in the hierarchy and rebuild/redeploy? If that shows the astronaut, then you should be able to run the app while I look at the issue above.Thanks!
David5 -
Optionsneerajwadhwa mod
@RosieLiu
I expect you have "deployed" your solution. In which case you will have to "start" it from the Windows Device Port (world globe). Select Apps in menu, look in alphabetical list find your app select from drop down and start click back to emulator.
If you are convinced there is a problem with your app got to "Completed" directory and use that version.
Anyway press the space bar twice and the keypad enter key on keyboard
Other than that try rebuilding as "Debug,x86,HoloLens Emulator"
"Start without debugging"
I am using completed version for testing, but it is still not working. I try to start from Windows Device Port and it fails.
When you ran this were there any errors in the Visual Studio 2015 Error Window
No, it just says "build and deploy successfully".
Just get this page once after several tries:
@RosieLiu,
Your last image shows the starting view for the Holograms 211 (as well as 210 and 212) application. You will need to tap (via right clicking with the mouse or pressing Enter on your keyboard) to proceed.
This page describes working with the Emulator.
David
@DavidKlineMS This is the page shows after I press enter to proceed. I could not get game page including Astroman on my screen.
And also, sometimes the program can not pop out and only emulator default page is shown. There is an error:
@RosieLiu,
If you press enter at this screen, does the astronaut appear? I am presuming that the first time you press enter, it is at a tile similar to what you show in your first image.
David
@DavidKlineMS No, nothing happens after I press Enter. It gets stuck at second page.
@RosieLiu,
Thanks for the update. I will investigate and see what I can find.
David
@RosieLiu,
David
@RosieLiu please ensure that the Human Input icon is highlighted with a blue box around it, then press Enter on your keyboard. That will get you past the Fitbox.
I just use another newer machine and everything goes well now! Thank you all!
I'm facing the similar issue. Whenever I start any program it just keep on showing "tap to place".
I'm not able to enable the "Human Input"
I tried re-installing the emulator but the problem is still there.
Also, every time I deploy the code following popup comes up
Following are the logs from output window:
'HoloOne.exe' (CoreCLR: DefaultDomain): Loaded 'c:\data\Programs\WindowsApps\Microsoft.NET.CoreRuntime.1.0_1.0.23819.0_x86__8wekyb3d8bbwe\mscorlib.ni.dll'. Cannot find or open the PDB file.
'HoloOne.exe' (CoreCLR: CoreCLR_UWP_Domain): Loaded 'C:\Data\Users\DefaultAccount\AppData\Local\DevelopmentFiles\HoloOneVS.Debug_x86.harshgodha\entrypoint\HoloOne.exe'. Symbols loaded.
'HoloOne.exe' (CoreCLR: CoreCLR_UWP_Domain): Loaded 'C:\Data\Users\DefaultAccount\AppData\Local\DevelopmentFiles\HoloOneVS.Debug_x86.harshgodha\System.Runtime.dll'. Cannot find or open the PDB file.
'HoloOne.exe' (CoreCLR: CoreCLR_UWP_Domain): Loaded 'C:\windows\system32\WinMetadata\Windows.ApplicationModel.winmd'. Module was built without symbols.
'HoloOne.exe' (CoreCLR: CoreCLR_UWP_Domain): Loaded 'C:\windows\system32\WinMetadata\Windows.UI.winmd'. Module was built without symbols.
'HoloOne.exe' (CoreCLR: CoreCLR_UWP_Domain): Loaded 'C:\Data\Users\DefaultAccount\AppData\Local\DevelopmentFiles\HoloOneVS.Debug_x86.harshgodha\UnityPlayer.winmd'. Module was built without symbols.
'HoloOne.exe' (CoreCLR: CoreCLR_UWP_Domain): Loaded 'C:\Data\Users\DefaultAccount\AppData\Local\DevelopmentFiles\HoloOneVS.Debug_x86.harshgodha\System.Runtime.InteropServices.WindowsRuntime.dll'. Cannot find or open the PDB file.
'HoloOne.exe' (CoreCLR: CoreCLR_UWP_Domain): Loaded 'C:\windows\system32\WinMetadata\Windows.Foundation.winmd'. Module was built without symbols.
'HoloOne.exe' (CoreCLR: CoreCLR_UWP_Domain): Loaded 'C:\Data\Users\DefaultAccount\AppData\Local\DevelopmentFiles\HoloOneVS.Debug_x86.harshgodha\System.Runtime.WindowsRuntime.dll'. Cannot find or open the PDB file.
'HoloOne.exe' (CoreCLR: CoreCLR_UWP_Domain): Loaded 'C:\windows\system32\WinMetadata\Windows.System.winmd'. Module was built without symbols.
'HoloOne.exe' (CoreCLR: CoreCLR_UWP_Domain): Loaded 'C:\Data\Users\DefaultAccount\AppData\Local\DevelopmentFiles\HoloOneVS.Debug_x86.harshgodha\WinRTBridge.winmd'. Cannot find or open the PDB file.
'HoloOne.exe' (CoreCLR: CoreCLR_UWP_Domain): Loaded 'C:\Data\Users\DefaultAccount\AppData\Local\DevelopmentFiles\HoloOneVS.Debug_x86.harshgodha\BridgeInterface.winmd'. Module was built without symbols.
'HoloOne.exe' (CoreCLR: CoreCLR_UWP_Domain): Loaded 'C:\Data\Users\DefaultAccount\AppData\Local\DevelopmentFiles\HoloOneVS.Debug_x86.harshgodha\System.Collections.dll'. Cannot find or open the PDB file.
'HoloOne.exe' (CoreCLR: CoreCLR_UWP_Domain): Loaded 'C:\Data\Users\DefaultAccount\AppData\Local\DevelopmentFiles\HoloOneVS.Debug_x86.harshgodha\UnityEngine.dll'. Symbols loaded.
'HoloOne.exe' (CoreCLR: CoreCLR_UWP_Domain): Loaded 'C:\Data\Users\DefaultAccount\AppData\Local\DevelopmentFiles\HoloOneVS.Debug_x86.harshgodha\Assembly-CSharp.dll'. Symbols loaded.
'HoloOne.exe' (CoreCLR: CoreCLR_UWP_Domain): Loaded 'C:\Data\Users\DefaultAccount\AppData\Local\DevelopmentFiles\HoloOneVS.Debug_x86.harshgodha\UnityEngine.Networking.dll'. Symbols loaded.
'HoloOne.exe' (CoreCLR: CoreCLR_UWP_Domain): Loaded 'C:\Data\Users\DefaultAccount\AppData\Local\DevelopmentFiles\HoloOneVS.Debug_x86.harshgodha\UnityEngine.UI.dll'. Symbols loaded.
'HoloOne.exe' (CoreCLR: CoreCLR_UWP_Domain): Loaded 'C:\Data\Users\DefaultAccount\AppData\Local\DevelopmentFiles\HoloOneVS.Debug_x86.harshgodha\System.IO.dll'. Cannot find or open the PDB file.
'HoloOne.exe' (CoreCLR: CoreCLR_UWP_Domain): Loaded 'C:\Data\Users\DefaultAccount\AppData\Local\DevelopmentFiles\HoloOneVS.Debug_x86.harshgodha\System.Net.Primitives.dll'. Cannot find or open the PDB file.
'HoloOne.exe' (CoreCLR: CoreCLR_UWP_Domain): Loaded 'C:\Data\Users\DefaultAccount\AppData\Local\DevelopmentFiles\HoloOneVS.Debug_x86.harshgodha\System.Private.Networking.dll'. Cannot find or open the PDB file.
'HoloOne.exe' (CoreCLR: CoreCLR_UWP_Domain): Loaded 'C:\Data\Users\DefaultAccount\AppData\Local\DevelopmentFiles\HoloOneVS.Debug_x86.harshgodha\System.Reflection.Primitives.dll'. Module was built without symbols.
'HoloOne.exe' (CoreCLR: CoreCLR_UWP_Domain): Loaded 'C:\Data\Users\DefaultAccount\AppData\Local\DevelopmentFiles\HoloOneVS.Debug_x86.harshgodha\System.Reflection.dll'. Module was built without symbols.
'HoloOne.exe' (CoreCLR: CoreCLR_UWP_Domain): Loaded 'C:\Data\Users\DefaultAccount\AppData\Local\DevelopmentFiles\HoloOneVS.Debug_x86.harshgodha\System.Threading.Tasks.dll'. Cannot find or open the PDB file.
'HoloOne.exe' (CoreCLR: CoreCLR_UWP_Domain): Loaded 'C:\Data\Users\DefaultAccount\AppData\Local\DevelopmentFiles\HoloOneVS.Debug_x86.harshgodha\System.Private.Uri.dll'. Cannot find or open the PDB file.
'HoloOne.exe' (CoreCLR: CoreCLR_UWP_Domain): Loaded 'C:\Data\Users\DefaultAccount\AppData\Local\DevelopmentFiles\HoloOneVS.Debug_x86.harshgodha\System.Text.Encoding.dll'. Module was built without symbols.
'HoloOne.exe' (CoreCLR: CoreCLR_UWP_Domain): Loaded 'C:\Data\Users\DefaultAccount\AppData\Local\DevelopmentFiles\HoloOneVS.Debug_x86.harshgodha\System.Runtime.InteropServices.dll'. Cannot find or open the PDB file.
'HoloOne.exe' (CoreCLR: CoreCLR_UWP_Domain): Loaded 'C:\Data\Users\DefaultAccount\AppData\Local\DevelopmentFiles\HoloOneVS.Debug_x86.harshgodha\System.Threading.dll'. Cannot find or open the PDB file.
Exception thrown: 'System.TypeLoadException' in Unknown Module.
Activation of the Windows Store app 'HoloOne_pzq3xp76mxafg!App' failed with error 'Could not find or load a type'.
The program '[4920] HoloOne.exe' has exited with code 1 (0x1).
