Running SharingService.exe from outside Unity causing issue
I am trying to run SharingService.exe outside of the Unity, while doing so I am running into error : Service failed to run w/err 0x0000427
But if I run SharingService from inside Unity, it runs all good. Can anyone help me with this issue ?
I am facing the same problem.. it will be great if you share a solution.. if you found one
