Read SQL data on HoloLens
Hello,
I have established connection from HoloLens to PhpMyAdmin page. I am able to insert data to the table from my HoloLens successfully. Unfortunately, I am not able to retrieve the data onto the HoloLens. However, it is working well on Unity3D but not on HoloLens. Here is my code:
using System.Collections;
using UnityEngine;
using UnityEngine.UI;
using System;
public class extractLocationDB : MonoBehaviour {
string URL = "http://192.168.60.115/holodb/extract_loc.php"; public string[] userdata; public Text txt; // Use this for initialization void Start () { } // Update is called once per frame void Update () { StartCoroutine(ExtractValues()); } IEnumerator ExtractValues() { WWW users = new WWW (URL); yield return users; string userdatastring = users.text; userdata = userdatastring.Split(';'); txt.text = userdata[0]; }
