Sending only the updated parts of reconstruction
I need to transfer to a desktop platform just the modified parts of the mesh generated by hololens to save some networking time. Is this possible? Also as a second question, incase if I process the mesh and generate a simpler model, would hololens continue over that simplified mesh or overwrite the generated mesh?
OptionsHoloSheep mod
@holocoder check out the mesh processing sections of the spatial mapping documentation:
Bear in mind that spatial mapping data is intended to be as faithful as possible to real-world surfaces, so any processing you apply risks shifting your surfaces further from the 'truth'.
You might find the section on handling surface changes of use as well.
WinHUGR YouTube Channel -- live streamed meetings6
