No sound in Origami: unity unable to load AudioPluginMsHRTF.dll during build
UnauthorizedAccessException: Access to the Path "Temp\StagingArea\Data\Managed\Plugins\X86\AudioPluginMsHRTF.dll" is denied.
System.IO.File.Delete (System.String path) (at /Users/builduser/buildslave/mono/build/mcs/class/corlib/System.IO/File.cs:179)...
I am using 64-bit Unity and build 5.4.0b20-HTP which includes HRTF already present. I don't see the Resources folder which would hold the sound files as well. Perhaps the build died upon the exception and didn't complete. Origami seems to work in every other way. I'll try loading HRTF separately to see if that helps.
Managed to do whole Origami tutorial in 5.4.0b20 without a glitch including spatial sound. Issue seems to be that clicking on sln file in App folder can lead you to multiple instances of VS and thus trigger build failures by locking the Temp/StagingArea file Unity uses to organize the build.
See:https://developer.microsoft.com/en-us/windows/holographic/best_practices_for_working_with_unity_and_visual_studio
for steps to reduce chances of this occurring.5
@rhenninger according to the Release notes for b20:
And if you drill into that link:
the docs mention:
Since Origami was created prior to the holotoolkit I would guess that it references that SetHRTF.cs and probably needs to be modified to use the AudioSpatializer component mentioned in the release notes.
Thanks for your reply. Further investigation suggests HRTF is not the real issue. Last night after posting, I tried dropping back to 2D sound to see if I could get a build to verify that HRTF might be the issue or just a symptom. Builds still failed, but now gave the "unauthorized" message about the WinRTLib dll that Unity uses for legacy, non-WinRT C# classes. So I suspected that my Unity install was broken somehow - permissions perhaps. The only unusual thing I recall doing was a clean and rebuild on the VS side - which I often do on projects.
This morning, I cleared and re-installed 5.4.0b20 and started to retrace my steps from scratch. My own trial project worked fine after deleting all folders but Assets and ProjectFiles. Then I brought in a fresh Origami folder set. From the build of the first step (just adding lights, spheres etc.), Unity complains with IO exception claiming the Temp\StagingArea\Data\Managed\Plugins\x86 directory is not empty. Maybe the Origami assets are not usable in 5.4.0b20? I'll keep experimenting. Last resort, I can drop back to b18 for the tutorial. That always worked.
One thought, the build did declare that it was including the HRTF plugin even though I had yet to reference it in code. (Probably in project audio settings). I'll check that out.
After more experiments: Did a project from scratch (Holograms 100) and added spatial audio using HRTF playing Ambient.wav from Origami on the cube. All works fine - even switched and restarted sound system when I plugged in my headset audio to override my usual DAW monitors and got the sample rate right without my intervention.
Can proceed to work out if Origami has issues as per HoloSheep's suggestion - though I've yet to work out where a setHRTF.cs script is attached in its assets.
Right now, I suspect my original problem may have been multiple (minimized) instances of VS open on the project at one time and that might have prevented the Unity project's Temp/StagingArea folder from being managed properly during builds. Just hunches at this time.
