How to convert EDB to office 365 using Stella EDB to PST converter
in General
Stella made best EDB to PST Converter software which an advance quality that able for recover EDB mailbox from all major version of EDB file as:- 5.0,5.5,2000,2003,2007,2010,2013,2016 and 2019 thereafter you can also able for convert EDB file to PST (support priv1 edb file and pub1 edb file) along with some different format as:- EML, MSG, EMLX, HTML, MBOX, MHTML etc. This SDR Microsoft EDB to PST conversion software is really popular application for extract file from EDB database and save EDB file to office 365.
For Read more visit here:- https://www.stelladatarecovery.com/blog/how-to-convert-edb-to-pst-in-office-365/
If you want to convert the EDB files to PST. I would suggest you the best and reliable tool, Shoviv EDB to PST tool.
Shoviv EDB to PST converter is a safe solution to fix and recover your corrupted EDB files and Export EDB to Office 365, Live Exchange Server, and Outlook. It also helps to save EDB data into HTML, RTF, Cal, vCal, and vCard format. Shoviv EDB to PST converter provides the free trial version and with the help of this trial version, you can migrate your first 25 items per folder.
Convert EDB mails to PST using Shoviv EDB to PST converter.
First download and install the tool
Then open the tool
**Add multiple EDB files **
Check and preview that files to Properly add
Export the files into other format
After that process is completed report is on your screen
