Deployment Problems
Hello,
I am attempting to deploy the Origami project to the HoloLens. However, I keep getting errors when I attempt to deploy. The Holograms 101 instructions say that I should deploy to Remote Device, however I do not have that option in the drop down. I have tried to deploy to the Device and the Remote Machine separately, but neither one of those is successful. I saw a response that says I am supposed to open the Project Properties and choose Debug on the left, but it is not their either. I'm not sure what to try next.
OptionsHoloSheep mod
@charitylovesvr use "Remote Machine" if you are using Wi-Fi to connect to your Hololens and "Device" if connected by USB.
Select the Origami (Universal Windows) project in the Solution Explorer and then click on Project Properties (right click is fastest way to get there)
On the debug tab you can enter the ip address of your HoloLens and then deploy.
I did everything you said and I received this error:
@charitylovesvr
Have you enabled dev mode on both your dev machine and your hololens and paired the device?
Can you connect over the Device Portal app to the device?
I have as I have done a successful deploy from my computer to this device previously.
@charitylovesvr if you have not made any major changes or installed/uninstalled any software since it was working last I suggest you try Restarting your HoloLens from Device Portal and then closing down and restarting Visual Studio. I found this has cleared a similar issue for me a number of times in the past.
I am in the Device Portal, but I can't see how to restart from here.
