Please help - DEP6100-Method not found: 'Boolean Microsoft.Tools.Connectivity.RemoteDevice.Ping()
I am banging my head since 10 days for deploying HelloHalograms app as per website https://developer.microsoft.com/en-us/windows/holographic/holograms_100 but i am getting "DEP6100 : The following unexpected error occurred during bootstrapping stage 'Connecting to the device '192.168.1.65'.':
MissingMethodException - '. HelloHolograms
. ". I tried with Emulator, Remote Machine with Halolense. But no luck.
I am running app in Window 10 Professional and Visual studio 2015 Community with latest version. And also i have installed "Tools (1.4) and Windows 10 SDK (10.0.10586).
I have observed one thing, latest frame work (10.0.10586) is not listing under target frame work even though i installed latest tools. I am not sure is could be the problem?
Could any one help me to fix this problem.
Thanks in advance.
OptionsTimK mod
I found a couple other posts of this issue from people deploying to other devices, e.g. Xbox One or Rasberry PI. The problem does appear to be a misconfiguration of Windows 10 SDK and/or Tools, possibly due to a bad install of Update 2.
Unfortunately, the best solutions seems to be to completely uninstall VS, Windows 10 SDK, and Tools and reinstall from scratch.
Here are links to a couple other forums concerning this issue for reference:
http://stackoverflow.com/questions/37095289/trouble-deploying-unity-game-to-xbox-one-dev-mode
https://social.msdn.microsoft.com/Forums/en-US/ab87fd5b-872b-407b-8d8b-005c98f1dd92/deployment-problem-from-vs2015-update-2-to-rasberry-pi-3-win10-iot-core-14295?forum=WindowsIoT#11b2a3e2-4904-44dd-a257-f348d2174e77
Thanks TimK,
It worked for me now. I really appreciated your help.
I got uninstalled Both Windows SDK and tools and installed it again. I did that before also couple of times by using VS installer. But this time i did using Control Panel >> Uninstall program. Finally it got worked for me.
Thank you
