Scale-Up/Down with Air-tap hold on the Corner
Hi All,
I would like to able to scale-up and down my hologram with the Air-tap hold on the corner of it. Anyone has suggestion how to do it?
Thanks and have a great day.
Cheers,
I assume you mean you need to do this for your own app and not the built-in holograms app.
The key to this, is using the Manipulation gesture documented here.
Unfortunately this is not implemented in the helper methods of HoloToolkit so you'll need to write it yourself, but it should not be terribly complicated. Just handle the ManipulationStarted, ManipulationUpdated and ManipulationEnded events.
