HoloLens® Emulator keeps loosing network connection after ca. 9 minutes
My HoloLens® Emulator always looses the network connection after about 9 minutes while debugging from within Visual Studio® 2015. This also happens with the 'Holographic DirectX® 11 App (Universal Windows)' template application (C#) provided by Microsoft®, showing a spinning cube.
Development Environment:
Windows® 10 Professional (Build 10586.494)
Visual Studio® 2015 (14.0.25424.00) Update 3
HoloLens® Emulator (10.0.14342.1018)
Thanks for any help.
OptionsJimbohalo10 ✭✭✭
@AdrianWenz said:
Windows® 10 Professional (Build 10586.494)Thanks for any help.
Well I have debugged this code for nearly 60 minutes.
The only difference is I used a later version of Windows 10But with Windows 10 Anniversary, launching, currently 2nd August, you may want to wait.
I am not sure this will fix problems as a lot of problems stem from the Hyper Manager and the changes between the DEBUG and RELEASE configurations.
HoloLens Device has this and I wonder if the Emulator being of the same code has this problemsI don't know if you want all the work updating you Win 10 Pro, so often. I am on the FAST Insiders update group and its been a bit bumpy.
