My continuing problem using WorldAnchorStore data
Gosh I feel I am very foolish not to get this issue solved when working on it for so long. To explain the situation, my US buddy has a HoloLens and I just have to use the HoloLens Emulator. So have to rely on both devices being reliably interchangeable in regards to what I am trying to achieve. In a nutshell , I am still finding it very difficult to use the WorldAnchorStore on the Emulator. I followed (perhaps incorrectly) the example suggested by the moderator Partick who, on the 26th April suggested a class called PersistoMatic which saves the WorldAnchor _variable only when the public boolean value _isLocated is true. A procedure is delegated to look at the tracking changes and then the isLocated variable is re-examined. Inspired by this piece of code I rejigged it to work in my environment.
static public WorldAnchorStore anchorStore = null; void Start() { WorldAnchorStore.GetAsync(StoreLoad); } private void StoreLoad(WorldAnchorStore store) { anchorStore = store; }
Now I have a series of static procedures which are called inside a MonBehaviour Class. One of these is to create a sphere:-
static public GameObject create_sphere(Vector3 pos) { var m = GameObject.CreatePrimitive(PrimitiveType.Sphere); if (pos!=Vector3.zero)m.transform.position = pos; comment = ""; WorldAnchor anchor = null; m.AddComponent<MeshFilter>(); m.AddComponent<BoxCollider>(); m.AddComponent<MeshRenderer>(); m.transform.localScale = Vector3.one * 0.04f; if (anchor_now) { anchor_now = false; anchor = m.AddComponent<WorldAnchor>(); anchor.transform.localScale = m.transform.localScale; if (anchor != null) { //we always seem to get to this point save_anchor_point(anchor); if (anchor.isLocated) { //currently this never gets called! comment = "world anchor is located"; posmarker.logmessage(comment); } } else { comment = "not added worldanchor"; } } else comment = "Click"; return m; } static public bool save_anchor_point(WorldAnchor wa) { var sa= new saveanka(wa, anchorStore); return sa.saved; }
The class which deals with storing the WorldAnchor is below
public class saveanka { WorldAnchor wa; WorldAnchorStore was; bool issaved = false; public saveanka(WorldAnchor wa,WorldAnchorStore was) { this.wa = wa; this.was = was; if (wa.isLocated) { wa.tag = System.DateTime.Now.TimeOfDay.TotalMilliseconds.ToString(); posmarker.comment = "added world anchor id: " + wa.tag; posmarker.logmessage(posmarker.comment); issaved = was.Save(wa.tag, wa); tellitsok = true; } else { wa.OnTrackingChanged += wa_OnTrackingChanged; } } private void wa_OnTrackingChanged(WorldAnchor wa, bool located) { if (wa.isLocated) { //Debug.Log("Saving persisted position in callback"); wa.tag = System.DateTime.Now.TimeOfDay.TotalMilliseconds.ToString(); posmarker.comment = "added and located world anchor id: " + wa.tag; issaved = was.Save(wa.tag, wa); if (issaved) tellitsok = true; //Debug.Log("saved: " + saved); wa.OnTrackingChanged -= wa_OnTrackingChanged; } } bool tellitsok { set { addcomment.comment = "anchor saved ok at: " + wa.transform.position.ToString(); value = true; } } public bool saved { get { return issaved; } } public bool located { get { return wa.isLocated; } } }
A sample set of anchor points looks like this on the Emulator:-
So in summary my question is:- _Does the WorldAnchor ever get the isLocated boolen set to true when using the Emulator or do I have to use the real HoloLens?
_
Many thanks in advance.
