SpatialMappingRenderer does not contain a definintion for RenderSetting
I encounter this while following the instructions for the "Origami" tutorial, upon trying to press "Play".Assets/Holograms/Support/Spatial Mapping/SpatialMapping.cs(44,86): error CS0117: 'UnityEngine.VR.WSA.SpatialMappingRenderer' does not contain a definition for 'RenderSetting'
I'm fairly experienced with C# but completely new to Unity. How do I fix this?
I'm using Unity 5.5.0b6.
...My Google-fu must've been weak. I haven't verified it yet (still installing) but I think it's because I have the wrong beta of Unity (the latest latest beta, instead of the latest HoloLens-specific beta).
... Yep. That was it. Ignore me...I'm new.
Same issue here. I updated Unity to 5.5.0b9 beta version and I can't Build the "Holograms 101E" solution that is on Hololens tutorials.
Hello
I have the same problem unity5.5 gives out these errors.
RenderSetting'Assets/Holograms/Support/Spatial Mapping/SpatialMapping.cs(44,40): error CS1061: Type
currentRenderSetting' and no extension methodcurrentRenderSetting' of type
UnityEngine.VR.WSA.SpatialMappingRenderer' could be found. Are you missing an assembly reference?Assets/Holograms/Support/Spatial Mapping/SpatialMapping.cs(45,40): error CS1061: Type
customMaterial' and no extension methodcustomMaterial' of type
UnityEngine.VR.WSA.SpatialMappingRenderer' could be found. Are you missing an assembly reference?I thought I was import the script in correct and missing some rendersetting files hope you guys found an answer.
Same problem here. Did you find a solution?
I changed the script "SpatialMapping.cs" with the new version: https://github.com/Microsoft/HolographicAcademy/blob/Holograms-101/Origami/Assets/Holograms/Support/Spatial Mapping/SpatialMapping.cs and it works
