Artifacts (or hallucinations) using spatial mapping
Hello,
I've followed all the tutorials and done my own projects, but the spatial mapping is not working very good. I am using the tutorial code for spatialmapping. If I remove the room models in the hololens everything is fine for some time, but after a longer period of using, the spatial mapping saves for example people and doesn't remove them. So I get some Artifacts, I want to place my models like in the holograms app, which is doing fine, but at some locations you can't see the object (using the spatial mapping renderer), because e.g. some stood there once. Sure is, it can be done, because the holograms app works also fine, at those same locations I can see the holograms (which I couldn't see in my app).
Thanks in advance
Is your application continually scanning?
Do you ever call SpatialMappingManager.Instance.StopObserver()?
If you do, have you tried calling StartObserver()?
Does this make the artifacts go away (eventually)?
