Is there a way to get the Battery level from the hololens through Unity?
I need to find a way to get the amount of battery left inside Unity, anyone got this working?
I've looked around for a solution but I cant seem to access System.Management or the Battery Class in Windows.Devices.Power. Any ideas on how to get this information?
    HoloSheepHoloSheep mod
    Answer ✓
    @toban
    When you say inside Unity, do you mean inside an app created in Unity?
    Are you wrapping your UWP code with the appropriate compile directives like so?
    #if WINDOWS_UWP
    using Windows.Devices.Power;
    #endif
    #if WINDOWS_UWP
            var aggBattery = Battery.AggregateBattery;
            var report = aggBattery.GetReport();
            Debug.Log("Battery Report: DeviceId - " +aggBattery.DeviceId.ToString());
            Debug.Log("Battery Report: Status - " + report.Status.ToString());
            Debug.Log("Battery Report: FullCharge - " + report.FullChargeCapacityInMilliwattHours.ToString());
            Debug.Log("Battery Report: Remaining - " + report.RemainingCapacityInMilliwattHours.ToString());
            Debug.Log("Battery Report: Charge Rate - " + report.ChargeRateInMilliwatts.ToString());
            Debug.Log("Battery Report: Design Capacity - " + report.DesignCapacityInMilliwattHours.ToString());
    #endif
    Based on a quick test deployed to a HoloLens I get the following results:
    Battery Report: DeviceId - AggregateBattery
    Battery Report: Status - Discharging
    Battery Report: FullCharge - 16710
    Battery Report: Remaining - 15664
    Battery Report: Charge Rate - -3409
    Battery Report: Design Capacity - 16500
    (plus a bunch of UnityEngineDebugbinding messages scattered in-between that I didn't bother investigating)
    which jives with the 94% that was showing on the device start screen at the time.
    Answer ✓
    @toban
    #if WINDOWS_UWP
    #endif
    #if WINDOWS_UWP
    #endif
    works like a charm
