Tap to place not working
Ho,fellas!
I'm having trouble with tapToplace code from hologram academy 101.
when i tap the object, it starts moving according to my gaze direction but i can't tap the object again because the cursor stops "embracing" the object. can you tell what i'm doing wrong?
i'm using a cube with a box collider a bit bigger than the cube itself. the origin og the cubeparent and the cube child are on the same position so i can't figure out what is going on.
I already figured out why. Cube parent,as child of my model collection must be a (0,0,0) from parent.
