Custom Mesh rendering problems
Hi guys
I work on a HoloLens application and i want to render some simple polygons. Each polygon marks a restricted area.
I used a mesh to solve this task, at the unity player it works fine but on HoloLens it doesn't display the mesh. Does the HoloLens ignore the mesh or have anybody an idea for this problem?
Vector3[] AllVertices = polygonCoordinates.ToArray();
for (int i = 0; i < AllVertices.Length-3; i = i + 2) { GameObject polygonGameObject = new GameObject("Polygon"); Mesh mesh = new Mesh(); mesh.Clear(); polygonGameObject.transform.SetParent(polygonContainer.transform, true); //Styles for Mesh MeshRenderer renderer = polygonGameObject.AddComponent(typeof(MeshRenderer)) as MeshRenderer; renderer.material.shader = Shader.Find("Particles/Additive"); Texture2D tex = new Texture2D(1, 1); tex.SetPixel(1, 1, Color.red); tex.Apply(); renderer.material.mainTexture = tex; renderer.material.color = Color.red; Vector3[] vertices = new Vector3[4]; vertices[0] = AllVertices[i]; vertices[1] = AllVertices[i+1]; vertices[2] = AllVertices[i+2]; vertices[3] = AllVertices[i+3]; mesh.vertices = vertices; int[] tri = new int[6]; //Upper triangle tri[0] = 0; tri[1] = 1; tri[2] = 2; //Lower triangle tri[3] = 2; tri[4] = 1; tri[5] = 3; mesh.triangles = tri; //Normals for nice rendering Vector3[] normals = new Vector3[4]; normals[0] = -Vector3.forward; normals[1] = -Vector3.forward; normals[2] = -Vector3.forward; normals[3] = -Vector3.forward; mesh.normals = normals; //For texture Vector2[] uv = new Vector2[4]; uv[0] = new Vector2(0, 0); uv[1] = new Vector2(1, 0); uv[2] = new Vector2(0, 1); uv[3] = new Vector2(1, 1); mesh.uv = uv; mesh.RecalculateNormals(); mesh.RecalculateBounds(); mesh.Optimize(); MeshFilter meshFilter = (MeshFilter)polygonGameObject.AddComponent(typeof(MeshFilter)); meshFilter.sharedMesh = mesh; GameObject.Instantiate(polygonGameObject); }`
Optionsjames_ashley ✭✭✭✭
Shader.Find is failing in your deployed project because Particles/Additive probably isn't getting included in the build (though it's there when you run from the editor). Try adding a Resources folder under Assets and putting your Additive shader there. Any files in Resources should be guaranteed to be included in your build. Then call Assets/Resources with your Find method instead of Particles/Additive.
www.imaginativeuniversal.com1
@jahrup,
@james_ashley
Thanks a lot you're great!
I'd try to debug it but i didn't see this error, probably i've got a problem with my debugger.
