Voice recognition does not work, except with Cortana
Good morning,
I have a weird problem. I used to use an Hololens and I did not have any problem with voice recognition.
I tried another device and the voice recognition does not work in my own apps (the ones that work fine on the other device) or when I say the classics "Hey Cortana", "Adjust", "Remove" etc, there is no answer from the device.
But if I start Cortana and I say exactly the same words, Cortana do the good researchs on the Internet. I have no problem with voice recognition when I navigate on the Internet. That's the only case it works. And I find this really strange.
I checked the privacy and the microphone is enabled for all apps.
The audio is enabled in the Mixed Reality Capture (I saw that on another topic).
Your help will be welcome! Thanks!
OptionsFrimy ✭
I did a reset and it works fine now. But if someone had the same issue and found another solution, it would be nice if another person deals with the same problem one day.
