Deploy problems
I recently downloaded the new version of unity.
I built the project with unity then I opened the solution with vs2015 like I usually do.
I can't deploy because there's this error.
Error CS0006 Metadata file:
It seems like something is missing but I can't figure out what it is since I never had this problem when I was using unity 5.4
Maybe there I made some mistakes during the build in unity...
I hope you can help me with this one.
Optionsjames_ashley ✭✭✭✭
Hi @angelicaHolo,
Delete the VS solution and export a new one from Unity. (I have to do this every so often, too, when mysterious error messages pop up.) Be sure to check build settings to make sure Virtual Reality is checked off and that spatial perception is also checked off as a capability (if you are relying on the Unity-Holotoolkit macros for automating build settings, there may be some issues in 5.5).
www.imaginativeuniversal.com5
Hi @angelicaHolo,
