Is Current System Powerful Enough for Hololens Emulator?
Hi Everyone!
Since I don't have a hololens, I plan on using an emulator to start building holographic apps.
I've read the system requirements for running a hololens emulator as stated here.
However, I still need some help in deciding on whether to upgrade my current system or invest in a new one.
My laptop:
- CPU: Intel(R) Core(TM) i3-3110M CPU @ 2.40GHz (2 cores, cache size 3MB)
- RAM: 4.00 GB
- OS: Windows 10 Home
- GPU: Intel(R) HD Graphics 4000
Here are some facts:
- The RAM can be upgraded to 8.00 GB.
- The graphics card supports DirectX11 and it's integrated to the motherboard and cannot be replaced with a better card.
- I am not sure if it uses a WDDM 1.2 driver (or later).
- I don't know if the BIOS is capable of SLAT and DEP.
Question:
Should I upgrade to Windows Pro, which I assume my system will support, and increase its RAM to 8GB, or is it best to invest in a more powerful system?
Thanks in advance!
Mike
Hey, are you be able to run the emulator on you dual core machine?
