Trying to build a puzzle style engine?
So what I am trying to do is to build an engine by moving holograms into their correct possitions.
I have 2 engines with 10 pieces each:
One which is assembled but its render its turned off.
Another one which is dismanteled into pieces, which you can pick up drag and drop to their correct position.
I have a working script for pc that when you drag the piece to its corresponding possition and it detects that is within the range of the radio of the piece that its render its turned off, the dragged piece gets destroyed and the hidden piece appears, giving the effect of snaping into its correct position.
Some how, this does not work with the HoloLens.
I have given the world anchor component to the base where everything is built uppon, but it still doesent respond to the pieces that i am moving getting into range of the hidden pieces. Any help will be apreciated.
2 scripts, one that makes the piece appear:
public GameObject objectD;
public GameObject objectO;
public AudioSource clickSound;
public float radio = 15f; public Renderer rend; // Use this for initialization void Start () { rend = GetComponent<Renderer> (); rend.enabled = false; } // Update is called once per frame void Update () { if (Vector3.Distance (this.transform.position, objectD.transform.position) <= radio && Input.GetMouseButtonUp(0)) { rend.enabled = true; //GameManager.IncreaseScore (1); clickSound.Play(); } }
One that destroys the draggable piece:
Vector3 originalPosition;
public float radio = 15f; // Use this for initialization void Start () { originalPosition = gameObject.transform.position; } // Update is called once per frame void Update () { if (Vector3.Distance (this.transform.position, objectO.transform.position) <= radio && Input.GetMouseButtonUp(0)) { Destroy (this.gameObject); } if (Vector3.Distance (this.transform.position, objectO.transform.position) >= radio && Input.GetMouseButtonUp(0)) { gameObject.transform.position = originalPosition; } }
I have tryed changing the Input.GetMouseButtonUp(0)) but nothing seems to work
This works on the PC.
Thank you for your help.
