Holelens Origami Unity sample does not generate Visual Studio project
I am following the Origami project tutorial. Every things seemed fine. I completed using Unity to generate a Visual Studio project in the App folder. However, when I check the folder, no files was there. What did I do wrong?
Thank you very much for your help.
Fireman
Unity has a console tab that might have some errors that can help narrow down the problem.
