Settings app stuck/crashed when opening WiFi settings when already connected
Hi, on one of our devices:
When I open the settings up when already connected to WiFi and then want to pen the wifi settings - it hangs/crashes. Only when disconnected it works. On the other device (which is from the same badge) I can open WiFi settings just fine then.
Has anybody observed something like that?
Do I need to reset the device causing the problem?
    Only time i noticed something like this is when i asked Cortana for my IP address. After that, it wouldn't let me go to the settings -> network screen unless i turned the device off and on again.
