Problem in Holograms 101E Chapter6-Spatial mapping.
Hello.
I am now following the contents of Hololens Tutorial.
In Holograms 101E Chapter6-Spatial mapping, I did same what the tutorial said, but I could not see the visual mesh of spatial mapping in Hololens emulator.
Rather, the objects I had created in the previous steps disappear and only the background, looks like ground and sky, appears...
I want the reason why I cannot see the right result in this chapter.
Please help me figure out how.
(https://developer.microsoft.com/en-us/windows/mixed-reality/holograms_101e)
@Inhae,
It's hard to know without seeing what you've done, but here are a few suggestions on spatial mapping things I often get messed up.
First, try running the completed 101 example to make sure it is the code and not your environment.
Next, double check that the Draw Visual Meshes box is checked.
Check to make sure a draw material is selected.
James
