What approach for solving a least squares system in a HoloLens Unity C# project?
Hi there,
I would like to find a least squares solution (a 3D point) to an intersection problem of arbitrary many lines. The math is easy, it is also easily written in Matlab. But Unity has no advanced linear algebra features, and I am struggling with finding tutorials on how to import UWP/C# libraries for linear algebra into the Unity project. Has someone experience with this? Does is it really boil down to writing own C# code for a LSE solver?
Regards
Fabian
I struggle with the same problem:
The documentation and guidance give zero guidance on app/project architecture.
I am trying to reference a class library and your problem could be solved in a similar way, by moving computations into a separate class library that depends on linalg packages from NuGet.
