Script not responding to tap events
So I have a script that's meant to plant flowers when the user gazes and clicks on an area in the scene. But for some reason, it only works when I use my computers mouse and not the Hololens AirTap on the Xbox Controller. I also tried the Inputtest script to see what was going on, and none of the airtap commands that I sent were registering.
This is the code that is responsible for the events :
using System.Collections;
using UnityEngine;
using UnityEngine.Rendering;
public class PFGarden : MonoBehaviour { [SerializeField] List<GameObject> prefabs; const string SHADER_PATH = "Hidden/Internal-Colored"; Material lineMaterial = null; MeshCollider col = null; Vector3[] vertices; int[] triangles; bool hit; Vector3 point; Vector3 normal; Quaternion rotation; void Update () { //var mouse = Input.mousePosition; //var ray = Camera.main.ScreenPointToRay(mouse); var headPosition = Camera.main.transform.position; var gazeDirection = Camera.main.transform.forward; RaycastHit info; hit = Physics.Raycast(headPosition,gazeDirection, out info); if(hit) { point = info.point; var t = info.triangleIndex * 3; var a = triangles[t]; var b = triangles[t + 1]; var c = triangles[t + 2]; var va = vertices[a]; var vb = vertices[b]; var vc = vertices[c]; Quaternion toQuat = Camera.main.transform.localRotation; toQuat.x = 0; toQuat.z = 0; //normal = transform.TransformDirection(Vector3.Cross(vb - va, vc - va)); rotation = toQuat; } if(Input.GetMouseButtonUp(0) && hit) { var go = Instantiate(prefabs[Random.Range(0, prefabs.Count)]) as GameObject; go.transform.position = point; go.transform.localScale = Vector3.one * Random.Range(0.4f, 0.5f); go.transform.localRotation = Quaternion.LookRotation(Vector3.forward); // * Quaternion.AngleAxis(Random.Range(0f, 360f), Vector3.up); } } const int resolution = 16; const float pi2 = Mathf.PI * 2f; const float radius = 0.5f; Color color = new Color(0.6f, 0.75f, 1f); void OnRenderObject () { if(!hit) return; CheckInit(); lineMaterial.SetPass(0); lineMaterial.SetInt("_ZTest", (int)CompareFunction.Always); GL.PushMatrix(); GL.Begin(GL.LINES); GL.Color(color); for(int i = 0; i < resolution; i++) { var cur = (float)i / resolution * pi2; var next = (float)(i + 1) / resolution * pi2; var p1 = rotation * new Vector3(Mathf.Cos(cur), Mathf.Sin(cur), 0f); var p2 = rotation * new Vector3(Mathf.Cos(next), Mathf.Sin(next), 0f); GL.Vertex(point + p1 * radius); GL.Vertex(point + p2 * radius); } GL.End(); GL.PopMatrix(); } void OnEnable () { //col = GetComponent<MeshCollider>(); var mesh = GetComponent<MeshFilter>().sharedMesh; vertices = mesh.vertices; triangles = mesh.triangles; } void CheckInit () { if(lineMaterial == null) { Shader shader = Shader.Find(SHADER_PATH); if (shader == null) return; lineMaterial = new Material(shader); lineMaterial.hideFlags = HideFlags.HideAndDontSave; } } }
Solved
