Microphone Example Sample Not Working Unity 5.5.1 and 5.5.2
I have tried the sample on both using 5.5.1 and .2 with no luck.
I see the error "ERROR: Tried to start microphone, but you don't have one plugged in, do you?"
Attempting to Record crashes the Editor.
    @Nonlin, do you have Microphone capability enabled in the build settings?
    NonlinNonlin
    edited March 2017
    @stepan_stulov I do in fact have the Microphone Enabled in the build settings.
    NonlinNonlin
    edited March 2017
    Solved the issue. It doesn't work when running in Editor over to Hololens. You have to deploy from Visual Studio for it to work.
    EDIT: Even running on the device recording causes a crash in Visual Studio.
