Difference between InputClickedEvent and InputClickedEventData?
Hello,
I had code that worked fine using the new Holotoolkit function (that replaces OnSelect() )
public void OnInputClicked(InputEventData eventData) { //Do something } public void OnInputClicked(InputClickedEventData eventData) { throw new NotImplementedException(); }
and now the program just go into the second function and I have the exception. It is like we exchange both functions, I don't understand how it works and the differences?
Thank you in advance for your help.
Optionsmark_grossnickle ✭✭✭
InputClickedEventData extends InputEventData and should be used for AirTaps.
1
Ok thank you!
