Error while building project hololens - Error: CS0006 "...\Assembly-CSharp-firstpass.dll" can not fo
SOLVED
I'm building a simple project for Hololens.
Unique scene with a simple Cube.
I follow this tutorials for make it:
-> https://developer.microsoft.com/en-us/windows/mixed-reality/holograms_100
-> https://developer.microsoft.com/en-us/windows/mixed-reality/using_visual_studio#hololens
-> http://pterneas.com/2016/04/04/getting-started-hololens-unity3d/
But this erros is display when I build:
I'm using the lastest version of Unity and Visual Studio:
Unity: v2017.1.0f3
Visual Studio: v15.3.2
The interesting thing is I've a friend with v15.2 release(26430.16) Visual Studio and he is build any Hololens application normally.
I already re-install my Visual Studio and Unity (for lastest version) but the erros continues.
I found this tutorial -> http://www.imaginativeuniversal.com/blog/2017/06/24/hololens-fix-visual-studio-2017-build-error/ but not works.
My output:
Restoring NuGet packages ... To prevent NuGet from restoring packages during compilation, open the Visual Studio Options dialog box, click on the Package Manager node and uncheck 'Allow NuGet to download missing packages during compilation'. 1> ------ Compilation started: Project: Assembly-CSharp-firstpass, Configuration: x86 Release ------ 1> Running SerializationWeaver ... 1> System.Collections.Generic.KeyNotFoundException: The supplied key was not present in the dictionary. 1> at System.ThrowHelper.ThrowKeyNotFoundException () 1> at System.Collections.Generic.Dictionary`2.get_Item (TKey key) 1> in UnityEditor.Scripting.Compilers.NuGetPackageResolver.Resolve () 1> in Unity.NuGetAssemblyResolver..ctor (String projectLockFile) 1> in usw.Weaver.ReaderParameters (String assemblyPath, ConversionOptions options) 1> in usw.Weaver.Weave () 1> in usw.Program.RunProgram (ConversionOptions options) 1> in usw.Program.Main (String [] args) C: \ Users \ luq.santana \ Documents \ _Unity3D \ BuildLimpa \ App \ GeneratedProjects \ UWP \ Assembly-CSharp-firstpass \ Assembly-CSharp-firstpass.csproj (196,5): error MSB3073: : \ Users \ luiz.santana \ Documents \ _Unity3D \ BuildLimpa \ App \ Unity \ Tools \ SerializationWeaver \ SerializationWeaver.exe "" C: \ Users \ luiz.santana \ Documents \ _Unity3D \ BuildLimpa \ App \ GeneratedProjects \ UWP \ Assembly- CSharp-firstpass \ bin \ x86 \ Release \ Unprocessed \ Assembly-CSharp-firstpass.dll "-pdb" -verbose "-web-engine = C: \ Users \ luiz.santana \ Documents \ _Unity3D \ BuildLimpa \ App \ BuildLimpa \ Unprocessed \ UnityEngine.dll "" C: \ Users \ luiz.santana \ Documents \ _Unity3D \ BuildLimpa \ app \ GeneratedProjects \ UWP \ Assembly-CSharp-FirstPass \ obj \ x86 \ Release \ x86 \ Release "" -lock = C: \ Users \ luiz.santana \ Documents \ _Unity3D \ BuildLimpa \ app \ GeneratedProjects \ UWP \ Assembly-CSharp-FirstPass \ project.lock.json "" @C: \ Users \ luiz.santana \ Documents \ _Unity3D \ BuildLimpa \ App \ GeneratedProjects \ UWP \ Assembly-CSharp-firstpass \ SerializationWeaverArgs.txt "-additionalAssemblyP ATH = C: \ Users \ luiz.santana \ Documents \ _Unity3D \ BuildLimpa \ app \ BuildLimpa \ Unprocessed "" -unity-networking = C: \ Users \ luiz.santana \ Documents \ _Unity3D \ BuildLimpa \ app \ BuildLimpa \ Unprocessed \ UnityEngine.Networking.dll "was terminated with code 1. 2> ------ Compilation started: Project: Assembly-CSharp, Configuration: Release x86 ------ 2> CSC: error CS0006: C: \ Users \ luiz.santana \ Documents \ _Unity3D \ BuildLimpa \ App \ GeneratedProjects \ UWP \ Assembly-CSharp-firstpass \ bin \ x86 \ Release-Assembly-CSharp-firstpass source file. Dll "can not be found 3> ------ Compilation started: Project: BuildLimpa, Configuration: Release x86 ------ 3> CSC: error CS0006: C: \ Users \ luiz.santana \ Documents \ _Unity3D \ BuildLimpa \ App \ GeneratedProjects \ UWP \ Assembly-CSharp-firstpass \ bin \ x86 \ Release-Assembly-CSharp-firstpass source file. Dll "can not be found CSC: Error CS0006: C: \ Users \ Luiz.santana \ Documents \ _Unity3D \ BuildLimpa \ App \ GeneratedProjects \ UWP \ Assembly-CSharp \ bin \ x86 \ Release \ Assembly-CSharp.dll "source file can not To be found ========== Compile: 0 successfully, 3 failed, 0 refreshed, 0 ignored ========== ========== Deployment: 0 Successfully, 0 Failed, 0 Ignored ==========
What must be happening? How I can solve it?
I just changed the version in
project.lock.json
file. It was withVersion=v10.0.10240´. I just ´find/replace
all and replace forVersion=v10.0
and works!I found a solution in this link: https://forum.unity3d.com/threads/net-scripting-backend-and-visual-studio-2017-3-incompatibility.487833/
project.lock.json
I have uninstalled Visual Studio 15.3 and installed 15.0. This also fixed the problem.
Moving Unity up to the latest .0p5 patch will also fix this: https://unity3d.com/unity/qa/patch-releases/2017.1.0p5
