Building Visual Studio Unity C# Projects problem Mixed Reality 250
Hey, I've been following the Mixed Reality 250 tutorial (https://developer.microsoft.com/en-us/windows/mixed-reality/mixed_reality_250) and I finished chapter 3. I wanted to check how it plays out in the Holo Lens Emulator so I tried to build it (Universal Windows Platform, target device Holo Lens, build type D3D, SDK 10.0.15063.0, checked Unity C# projects) but received only a handful of errors.
They're all associated with the ControllerVisualizer script which is attached to Controllers object under MixedRealityCameraParent->MixedRealityCamera. There are 2 blocks of code which, if commented out, allow me to build the project but I'm pretty sure that's not the best way to solve things and that's why I ask you for an explanation. Are they necessary? Am I doing something wrong? Is the Microsoft tutorial simply unfinished?
I've tested it on the newest beta of Unity 2017.3.0b3 and on the newest release candidate 2017.2.0f2.
if !UNITY_EDITOR
if (GLTFMaterial == null) { if (LeftControllerOverride == null && RightControllerOverride == null) { Debug.Log("If using glTF, please specify a material on " + name + ". Otherwise, please specify controller overrides."); } else if (LeftControllerOverride == null || RightControllerOverride == null) { Debug.Log("Only one override is specified, and no material is specified for the glTF model. Please set the material or the " + ((LeftControllerOverride == null) ? "left" : "right") + " controller override on " + name + "."); } } // Since the SpatialInteractionManager exists in the current CoreWindow, this call needs to run on the UI thread. UnityEngine.WSA.Application.InvokeOnUIThread(() => { spatialInteractionManager = SpatialInteractionManager.GetForCurrentView(); if (spatialInteractionManager != null) { spatialInteractionManager.SourceDetected += SpatialInteractionManager_SourceDetected; spatialInteractionManager.SourceLost += SpatialInteractionManager_SourceLost; } }, true);
and
if !UNITY_EDITOR && UNITY_WSA
/// <param name="sender">The SpatialInteractionManager which sent this event.</param> /// <param name="args">The source event data to be used to set up our controller model.</param> private void SpatialInteractionManager_SourceDetected(SpatialInteractionManager sender, SpatialInteractionSourceEventArgs args) { SpatialInteractionSource source = args.State.Source; // We only want to attempt loading a model if this source is actually a controller. if (source.Kind == SpatialInteractionSourceKind.Controller && controllerDictionary != null && !controllerDictionary.ContainsKey(source.Id)) { SpatialInteractionController controller = source.Controller; if (controller != null) { // Since this is a Unity call and will create a GameObject, this must run on Unity's app thread. UnityEngine.WSA.Application.InvokeOnAppThread(() => { // LoadControllerModel is a coroutine in order to handle/wait for async calls. StartCoroutine(LoadControllerModel(controller, source)); }, false); } } } private void SpatialInteractionManager_SourceLost(SpatialInteractionManager sender, SpatialInteractionSourceEventArgs args) { SpatialInteractionSource source = args.State.Source; if (source.Kind == SpatialInteractionSourceKind.Controller) { ControllerInfo controller; if (controllerDictionary != null && controllerDictionary.TryGetValue(source.Id, out controller)) { controllerDictionary.Remove(source.Id); UnityEngine.WSA.Application.InvokeOnAppThread(() => { Destroy(controller); }, false); } } } private IEnumerator LoadControllerModel(SpatialInteractionController controller, SpatialInteractionSource source) { GameObject controllerModelGameObject; if (source.Handedness == SpatialInteractionSourceHandedness.Left && LeftControllerOverride != null) { controllerModelGameObject = Instantiate(LeftControllerOverride); } else if (source.Handedness == SpatialInteractionSourceHandedness.Right && RightControllerOverride != null) { controllerModelGameObject = Instantiate(RightControllerOverride); } else { if (GLTFMaterial == null) { Debug.Log("If using glTF, please specify a material on " + name + "."); yield break; } // This API returns the appropriate glTF file according to the motion controller you're currently using, if supported. IAsyncOperation<IRandomAccessStreamWithContentType> modelTask = controller.TryGetRenderableModelAsync(); if (modelTask == null) { Debug.Log("Model task is null."); yield break; } while (modelTask.Status == AsyncStatus.Started) { yield return null; } IRandomAccessStreamWithContentType modelStream = modelTask.GetResults(); if (modelStream == null) { Debug.Log("Model stream is null."); yield break; } if (modelStream.Size == 0) { Debug.Log("Model stream is empty."); yield break; } byte[] fileBytes = new byte[modelStream.Size]; using (DataReader reader = new DataReader(modelStream)) { DataReaderLoadOperation loadModelOp = reader.LoadAsync((uint)modelStream.Size); while (loadModelOp.Status == AsyncStatus.Started) { yield return null; } reader.ReadBytes(fileBytes); } controllerModelGameObject = new GameObject(); GLTFComponentStreamingAssets gltfScript = controllerModelGameObject.AddComponent<GLTFComponentStreamingAssets>(); gltfScript.ColorMaterial = GLTFMaterial; gltfScript.NoColorMaterial = GLTFMaterial; gltfScript.GLTFData = fileBytes; yield return gltfScript.LoadModel(); } FinishControllerSetup(controllerModelGameObject, source.Handedness.ToString(), source.Id); }
