How to switch from 2D Xaml view to 3D holographic view (Directx)
Hello,
I've been able to get both xaml UWP apps and the 3D holographic sample running on the emulator but am Having trouble starting out with a xaml view and then switching to a holographic view. The docs say that this is possible and give some Classes (https://developer.microsoft.com/en-us/windows/holographic/app_model) to use but I haven't been successful yet. Is there an example of this somewhere?
Thank you,
Kyle
OptionsNajaDojo ✭
This is pretty easy to put together with the Visual Studio templates. Create a new Holographic DirectX 11 App. Then create another Xaml project (Blank App is enough). Copy contents of the 3D app project into the Xaml project. You'll need to actually combine the pch.h and remove the main() function from the AppView.cpp. Add a button to the Xaml app and make the handler something like:
void HolographicDxXaml::MainPage::Button_Click(Platform::Object^ sender, Windows::UI::Xaml::RoutedEventArgs^ e)
auto newView = CoreApplication::CreateNewView(ref new HolographicDX::AppViewSource());newView->Dispatcher->RunAsync( CoreDispatcherPriority::Normal, ref new DispatchedHandler([this]() { auto viewId = ApplicationView::GetForCurrentView()->Id; CoreWindow::GetForCurrentThread()->Activate(); CoreApplication::MainView->Dispatcher->RunAsync( CoreDispatcherPriority::Normal, ref new DispatchedHandler([viewId]() { auto asyncAction = ApplicationViewSwitcher::SwitchAsync( viewId, ApplicationView::GetForCurrentView()->Id); })); }));
That's just example code you'll want to actually manage the newView and viewId so you could switch back and forth. https://github.com/Microsoft/Windows-universal-samples/tree/master/Samples/MultipleViews has some better practices.
6
Ahhhh was so simple. Thank you very much. Very helpful.
