How do i make something continuously spin and have a bobbing or hovering movement?
I created a pedestal for the electric motor of my vehicle that is supposed to showcase the motor rotating along an axis in a hovering container like in the picture.
OptionsHoloSheep mod
@WEDimagineer you need to put an empty game object as a parent and use the parent kind of like a wrapper.
You can adjust the child's relative position (relative to the parent) and then rotate the parent game object.
Since the parent is an empty game object its origin will be at it 0, 0, 0 position. By adjusting the child's position it just moves relative to its parent, so you move it to a place where its desired origin overlaps the parents 0, 0, 0 position. Then when you rotate the parent, the child will go with it and it will appear to rotate from the desired origin (as long as you place the child at the correct offset position.
This post with pictures might help explain.
@WEDimagineer
To rotate a gameobject you can use code like:
myGameObject.transform.localRotation = Quaternion.Euler(0, rotAngle, 0);
or
myGameObject.transform.Rotate(Vector3.up, rotSpeed * Time.deltaTime);
in the Update routine of a script attached to the object hierarchy.
HTH.
@HoloSheep
is there a way to rotate at the center instead of the origin? I know I asked this already, but isn't there a way to rotate it along the axis of a different part, like the cylinder below it?
