floor spatial mapping
felsiska
I'm trying to map only the floor and remove all other vertices other than floor. similar to 3d viewer beta lock to floor scenario. but how do I search for the spatial mesh for the vector that has lowest Y value and an up vector? grateful if anyone could guide me.
@felsiska ,
Finding plane meshes that are floors is built into the HoloToolkit (which is considerably easier than trying to do it by hand since these spatial understanding scripts call a C++ dll).
You can find sample code in HoloToolkit\SpatialMapping\Tests\Support\SpatialProcessingTest
For a fuller example you should refer to the Spatial Understanding Feature Overview Example in HoloToolkit-Examples and specifically take a look at the LevelSolver class: HoloToolkit-Examples\SpatialUnderstanding\SpatialUnderstanding-FeatureOverview\Scripts\LevelSolver.cs
@james_ashley
thx for the advice. roughly understood spatialProcessingTest but not LevelSolver. please correct me if I'm wrong. spatialProcessingTest uses SurfaceMeshesToPlanes to find the appropriate mesh positions and load a plane prefab through SurfacePlane. I can use SurfaceMeshesToPlanes to load planes only onto the floor. but the other vertices will cause objects to collide. or is there any way that I can disable spatial mapping after planes have been created?
@felsiska,
You've got it. Then to ensure that only floor planes are created, you can set the mask property of SurfaceMeshesToPlanes like this:
surfaceToPlanes.drawPlanesMask = = PlaneTypes.Floor;
this filters the plane types that can get instantiated.
@james_ashley
understood. is there a way to disable the spatial mapping when clicking on maybe a button? I do not want objects to collide with other vertices.
@james_ashley
also, the floor planes are 20-30cm higher than real floor surface. I've deleted the room meshes and recalibrated but still have this problem. any suggestion?
