Remove occlusion for UI only
Hello everyone,
I have a simple project where I put a hologram in the room, I added a SpatialMapping GameObject with the Spatial Mapping Renderer and the Spatial Mapping Collider in the scene and all is OK, my object is correctly occluded.
The problem is that I have UI items like menus, cursors etc and they are occluded too. I don't know what to do to occlude only some objects. I tried layers, putting UI as 0 and wanted occluded objects as 31, I modified the layer Collision Matrix but it does nothing.
I looked for topics on the forum but just found one with no answer.
If you can help me, thank you in advance and have a great day.
OptionsDavon92 ✭
i believe there is a VR shader/Material in unitys VR Samples that you can set as the material for ui components that will render it ontop of anything.
Yeah thank you I used GUI 3D text shadder and I can use it even on object that are not text. Thank you!
