Hold gesture to move object
Have a very basic question as I am a new bee.Please bare with me.
Like traditional windows programming I am trying to perform drag drop on hololens using hold gesture. I already watched 211 video and found lots of scripts like handamanger,interactible and gesturemanager and hence getting confused. I will lose focused object if gaze at some other place in my scene. For hold gesture, I just want to do drag drop which is not relying on gaze as I can gaze at other place while dragging. Could you please provide a simple script to achieve it.
@Learner
If you set a reference to the gameobject, that you are gazing at and that you want to move, when you perform the initial tap to hold gesture you should then be able to move the same gameobject during your manipulation regardless of where you gaze afterwards.
You can do it :-)
Experiment a little and you will learn a lot.
