tutorial flaws
in Discussion
Where do I report flaws in the Hololens Academy tutorials? I just started this week with Hololens and Unity and I notice that the tutorial https://developer.microsoft.com/en-us/windows/holographic/holograms_100 does not work. If you create the example application using the steps outlined, then you end up with a scene that has no light source. Launching the application produces a splash screen and then you get a black world. For the very first tutorial, I would suggest complete coverage of all details necessary to get the first app running would be essential. The section "Chapter 3 - Create a Hologram" should be expanded to include the necessary content in Unity
@iraytrace,
You can report issues either here, or on the Holographic Academy GitHub repository. I will investigate what you are seeing an work with the team to get necessary changes added to Holograms 100.
David
The new location of the updated tutorial Holograms 100 - Chapter 4 - Create a Hologram and the updated video tutorial Holograms 101 are now available
