Save a string to a text or cvs file on HoloLens
Hi everyone
I am new to programming and HoloLens development, and I am recently working on an application that requires me to store information in a text, cvs, or xml files on the HoloLens.
I am still looking into Serialization stuff in Unity (since I don't need the read function right now), so I tried to go for an easy path that is to store the data as txt format.
I am able to write a line to the console through Debug.Log (I wrote a function that will return a string) and I what I am trying to do now is to write the line into a txt file. So I guess the two questions I have are:
What is the file path on the HoloLens, am I be able to create a save information to a txt file on HoloLens? And if possible, could someone give me an example how to store it?
Could this file be opened through the whole process? I don't need to modify the file, I just need to add a new line to the file whenever I tap on the button in the application.
Thanks a lot
@Cozywolf
Maybe this post will help get you started.
I'm looking to do the same however whenever the user gazes at an object, I would like timestamps to be created within an Excel or CSV file for when the person gazes at the object and then looks away from the object.
OnGazeEnter - timestamp enter time within the spreadsheet yyyy-mm-dd h:mm am/pm
OnGazeLeave - timestamp exit time within the spreadsheet yyyy-mm-dd h:mm am/pm.
Thanks
I kind of figured it out through some articles and trial and errors. Here is the code I have, the code will write the file to "User Files\LocalAppData[APP name]\LocalState"
@Cozywolf
Hi Cozywolf
Thank you for sharing your code. Does this code works in a master build too?
edit: actually I try to run it on a master build in a modified way and get errors. (only on master build....) does someone knows what I m doing wrong?
