Holograms 101 has the answers to the video
Jimbohalo10
https://dev.windows.com/en-us/holographic/holograms_101
Has all the answers to where is Project Origami from the video
https://youtube.com/watch?v=qotpUpIQxVU
You will need https://unity3d.com/unity/beta
Unity 5.4.0b10
Released: March 14, 2016
and Visual Studio 2015 Update 2 RC and Windows 10 Technical Preview build 14291 at least
I have now realised that these need Unity 5.1.4f1 (64-bit), NOT 5.4 or 5.5(?) to run the unity package is in the Completed\Assets directory of each example , just click it there is an error about missing assembly, but still will start player unfortunately have to wait till 30h March2016 or later ;-) to get the HoloLens emulator working with Unity
You need this version of Unity for HoloLens development:
http://unity3d.com/pages/windows/hololens
Everything works for me 101,230,Origami,GalaxyExplorer, and all I had to do was reinstall VS 2015 Update 2 from the link.
Really impressed thanks
@Jimbohalo10 are you using the hololens emulator? and are you able to see the origami on the emulator?.
Yvan
Hololens Developer Rookie
Yvan, Origami should work in the emulator. Can you double check the transforms for the camera and OrigamiCollection in Unity?
Yes I have the HoloLens Emulator running, just finished Planetarium in 230, did initial work on 101 Origami
@Patrick they are correct as the one in the tutorial x=0, y=-0.5, z=2
Yvan
here is the error message i get when i only see a white dot in the middle of the emulator and my debugger stops
Yvan
Just finished tutorial of Chapter 8 the Finale. This seemed difficult to make work so give this a try Tutorial: - Building HolographicAcademy-Holograms-101 Chapter 8 – The Finale
Create a new directory path, to stop potential corruption of the new download
