Unity Audio Capabilities
Hello Guys,
I am looking to parse the microphone audio stream data, with the Microphone capabilities in unity "VideoCapture, DictationRecognizer, GrammarRecognizer, and KeywordRecognizer"
I don't think I have the ability to turn on the microphone and capture the stream. Can you tell me the best way to capture the audio stream on the Hololens and would you have an example using C#?
Thank you
OptionsJackson mod
You do have the ability to record from the Microphone.
Make sure you have the Microphone capability turned on in "Edit > Project Settings > Player"
Then take a look at this class for reference:
https://github.com/Microsoft/HolographicAcademy/blob/Holograms-212-Voice/Completed/ModelExplorer/Assets/Scripts/MicrophoneManager.csYou can see that StartRecording() returns an AudioClip that you can use.
5 -
OptionsJackson modYou can get the raw data from the AudioClip with GetData:
http://docs.unity3d.com/ScriptReference/AudioClip.html
This will give you an array of floats -1..1 that you can do whatever processing on that you need to.5
Hello Jackson,
I did not ask my question 100%. So i did see that you can create a audio file with the microphone however i am looking to gain access to the audio stream bytes.
I want to look at sound frequencies I feel i am going to need to write some type of a library using directx to gain access to the stream. Is this correct?
Thanks I will try that tonight
