Does anyone know a good software to fix 3d models?
I have a simplified model of a wheel that isn't looking right. It must be broken at some point as you can see by the hollow appearance at the rim where the gold meets the rubber in the picture. can anybody recommend a good model repair software that works with fbx files? Thanks.
@WEDimagineer,
If you need something powerful and free, you should try Blender.
If you have money to spend, then try Cinema 4D. There's a free trial version, too.
3ds Max is really hardcore but also has a free trial.
@WEDimagineer,
There is also Rhino with a free trial period. FWIW, I found it easier to use than Blender and 3ds Max.
