Reducing jitter on far away objects
Objects (and the room scan) more than a few meters away from the device seem to jitter quite a lot. The error increases with distance. Any way to reduce this? It seems to be related more to positional movement than rotational.
OptionsAmerAmer ✭✭✭Where is your stabilization plane set? You can try combining it with a world anchor. Finally if your fps is not close to 60, jitter will happen as part of the slow prediction refresh rate. The lens in that instance can't keep up with the movement and it's catching up.
Developer | Check out my new project blog5
Thanks, setting the stabilization plane explicitly really helps.
