Can someone capture a room using their physical device and send it?
Can someone capture a room using their device using the Device Portal and send it to me? Thanks.
neerajwadhwa mod
@Sai please feel free to use the rooms that come with the emulator. You can load them from here: %ProgramFiles(x86)%\Program Files (x86)\Microsoft XDE\10.0.11082.0\Plugins\Rooms
This is documented here.
It would be handy to use the *.room files (that are generated in the 230 holographic academy) in Unity so you can test without deploying to the emulator everything. I'm trying to generate a *.room file from the emulator using one of the emulator rooms but without success so far - https://forums.hololens.com/discussion/357/saving-mesh-from-hololens-emulator-230#latest
