Error 403 on Uploading file with REST API and Wifi
Hello,
I have made a program to upload files on Hololens without using the web interface. It uses the Rest API as do the web interface.
This works perfectly when connected in USB.
But on Wifi I receive an error 403. As long as the web interface allows the user to upload a file on Wifi, I don't understand what I'm missing.
Any clue ?
OptionsDavidKlineMS mod
@Hutin,
It appears that you are running into a security feature of the Windows Device Portal. Without passing the proper token in the request headers, Windows Device Portal will only allow GET calls. PUT, POST, etc will all return the 403 code you are seeing.You may be interested in the Windows Device Portal Wrapper project on GitHub. It implements automatic security handling and has an issue open to implement the manual security mechanism. I highly recommend using (and contributing to) the wrapper project as it supports all Windows 10 devices, including Xbox One.
Alternatively, you can disable HTTPS in the Windows Device Portal on your HoloLens. This will cause it to behave over WiFi like it does over USB. I do not recommend this option unless you are on a secure and trusted network.
David2
@Hutin,
David
Alright, I will run it without SSL for the moment, thank you for the answer.
Nevertheless I don't undestand what "proper token in the request headers" you are talking about?
