Deploy to device in diferent network
Is it possible to deploy to a device that is in another network?
I wanted to deploy to the client device that is another physical location. Is this possible?
Best regards
@JPItPeople,
Are you looking to side-load an application onto the remote HoloLens? If so, you can package your project in Visual Studio and have the client install using the Windows Device Portal.
Here are the steps for Visual Studio:
When complete, you will have a folder that contains a Dependencies and the project's .appx file. Send these to your client and have them connect to their HoloLens using the Windows Device Portal and install from the Apps tab.
David
