Creating an App with visual studio?
Is it possible to create an app with visual studio and not unity?
I have only seen tutorials for unity and visual studio?
Is there tutorials for just setting up a visual studio solution to deploy on hololens?
My app needs to allow the user to airtap any item in your real world and the hololens will then take a picture of the view. Then do some things with that picture and return some details to the user.
So I don't think I need to use unity to develop this.
Optionsjames_ashley ✭✭✭✭
You can build a standard 2D UWP app and use the MediaCapture class to take pictures with the HoloLens Locatable camera. (The third kind of project is a DirectX project in Visual Studio, but it doesn't sound like you want to do that. It's pretty hairy.)
www.imaginativeuniversal.com5
@JD_Holo_Dev,
I found a sample project for the 2d UWP Thanks.
