@KingPepito Thanks for the Code Sample
I have one question. How did you manage to include the "ZXing"? When I try to install the package it says my .NET is just on 3.5 and I need 4.0 for ZXing. I also cannot change my .NET to a higher version. So how did you do it?
Edit: @baskievits : sry I didn't see your post. But I think we have the same question.
@OptiLenso @baskievits have a look at Mike Taulty blog post about this topic https://mtaulty.com/2016/12/28/windows-10-uwp-qr-code-scanning-with-zxing-and-hololens/
Hi @OptiLenso, sorry for the late response,
I used Zxing.net.mobile package, hope it will help
The example of Mike Taulty is not working for me unfortunately. I'm having problems with the Windows.Media.Capture.Frames namespace. I cannot import it. Is anyone else experiencing this problems?
@Roel
yes I got the same problem and it is the same like before. The dll has to be framework 3.5 and not 4.x.
@mtaulty How did you manage to import your QRCode Reader dll ?
I have been able to figure out what was not working for me. It appeared that I didn't choose Anniversary as target platform. When I updated my SDK version, I was able to do so.
Now I'm experiencing another problem: when scanning one code and then another, the whole app crashes and I see in my output that I receive an Access Denied error.
I try to develop continuous scanning in my app. When using Mike's tutorial, I can only scan one time. When scanning a second time, the app crashes, with the following line:
The program '[3200] Barcode Reader.exe' has exited with code -1073741819 (0xc0000005) 'Access violation'.
Can someone please help me? Putting try .. catch around everything doesn't help.
I don't know that I did anything 'special' to reference the assemblies that I referenced in the blog post - I'll see if I can find the Unity project and will add it to the github repo if I can.
Mike
I am not familiar with the code Mike is using. But access violation indicates that you are trying to access memory that does not belong to your current process.
https://goo.gl/GwYaGX
Maybe try stepping through your code with the debugger and see where the error occur exactly.
I use the code from @mtaulty 's blog too. I get the same error as @Roel when I try to scan a second qr code.
If your machine has multiple graphics adapters, Unity may have created a WindowContext on the wrong adapter. If you experience a black screen when playing, please restart the Editor.
The program '[5800] QRScanning.exe' has exited with code -1073741819 (0xc0000005) 'Access violation'.
For my application it is necessary to scan more than one code. Should someone get a working solution to scan more qr codes please let me know.
The Plugins QR Code/Barcode Scanner and Generator have supported Windows Phone/WSA platform,Please Update from assetstore.> @avatar said:
The Plugins QR Code/Barcode Scanner and Generator have supported Windows Phone/WSA platform Recently.Please see it in assetstore.
@elecV6 : This is quite possibly a Unity issue. Try Assets > Reimport All. Ive heard this fixing things before. MAKE SURE your DLLs are in place before re-importing. Unity will set everything back up for you.
Also, try this. I have created a scene in Unity that I used just for Barcode scanning. Once the scan has finished, I unload that scene and remove any unused assets. This "should" remove anything you had in memory and you would be able to reload the scene again additively for another single scan. its the only work around I have right now to do multiple scans in a row. If anyone comes up with something else, I am hopeful.
I am also having this crash problem on Hololens , can someone please help.
thank you
Dheeraj Singh
Same here: I did use Mike's approach, and tried several ZXing assemblies. However, they generated a file load exception when I started scanning.
I've added the Unity and library code in github if anyone is willing to have a look at it.
Please see our thread here > https://forums.hololens.com/discussion/comment/13785#Comment_13785. It seemed to solve the issue. I will write up a blog post when I get a chance. I am not coming across any access violations and I am using ZXing.net
I managed to get some time to look at the code that's getting referenced here and I could reproduce the Access Violation which was happening down deep in Windows.Media.dll and relates to disposing a MediaFrameReader and a MediaCapture at the same time. I would find on HoloLens that this would crash every 2-3 scans. I could reproduce this on PC as well as HoloLens but less frequently.
I've modified the code to try and workaround the issue as best I can as the crash is outside of my code.
If people have success/failure with this, let me know and I'll take a look at it again.
I could not make it to work with HoloLens, could you help me please?
