How to customize Holographic Shell just like customize Win10 Start Menu?
OptionsDavidKlineMS mod
Please submit your suggestion via the Feedback Hub. Our team actively reviews user feedback and feature requests.
David5
You cannot change the tile size. Adding more tile is done by navigating the app list (plus button on the right) and then longpress (longtap) an app. In the context menu you'll find "Pin...".
DonPepe, Thanks for your reply.
But What I want is programmable customization the Holo shell but not manually operation by user.
@johnny,
David
