Understand when a user clicked (gaze) on particular object in DirectX (newbie)
how I can understand when the user "clicked" on a particular object? In example on the cube of the spinningcuberender base template for Hololens?
thanks
OptionsJackson mod
You will have to perform some ray collision between the HoloLens and the holograms in your scene.
You will need a ray defined by the HoloLens position and the facing direction. Use an XMVECTOR:
https://msdn.microsoft.com/en-us/library/windows/desktop/ee420742(v=vs.85).aspxThen you will probably want to add a bounding volume to each hologram in your scene:
https://msdn.microsoft.com/en-us/library/windows/desktop/microsoft.directx_sdk.directxcollision.boundingsphere.intersects(v=vs.85).aspx
(This is optional, but will speed up your collision detection if you have multiple holograms in your scene)Check if your ray intersects with any of the bounding volumes in your scene (that you added to your holograms)
Then check to see if the ray intersects with any of the triangles in that hologram:
https://msdn.microsoft.com/en-us/library/windows/desktop/hh855922(v=vs.85).aspxIf your ray intersects with multiple holograms' bounding volumes, you will want to check the closer hologram for triangle collision first, then break when you get a valid collision.
Also note: collision can get pretty expensive as you add more objects to your scene. You may wish to register each of your holograms to a scene graph and do some space partitioning in your scene to optimize these ray checks.
Alternatively, you might want to look into using a physics engine that will do all of that for you.
