how to use several Unity scene ?
Hello
I have a Unity project for Hololens and i want to use several scenes with ServiceManager.LoadScene. This method work on Unity emulator but not on HoloLens emulator or HoloLens. is there a solution to use several scenes with the HoloLens ?
Thanks
It should work on the device. What error are you getting?
Thank you for your help ! I didn't had the great update of holotools kit. I have solved the problem thank you anyway.
